The model that shows existing Queries, aggregations does not reposition if they are in the bottom of the window. So part of the model is not visible. See image below. The only work around is to scroll out using CTRL + scroll wheel and hopefully click on the correct place.
Even Add aggregation model does not reposition. However add query model will reposition.
I have tried in MS edge and Chrome in windows 10. Both have the same behavior.
Im using Tulip version LTS 8. I have seen same behavior in LTS 7.2 and R232 trial account.
All OS and browser version info added below.
