Hi, I want to know if we’re able to add 360° Images on Tulip?
Probably, but I’m not sure if this will work out of the box with configuration or require some change on our end. Do you know the file format of the images you already have and what tools, utilities, or viewer you are using?
This is a great idea btw.
I haven’t bought a kit or tool for this yet, I could adapt to any adjustments you may create in the future.
