Wondering if there is demand for this - our AI helper for creating user stories acceptance criteria made me think of this with one of its suggestions.
Could there be an optional parameter for Error and Message actions that would allow a specified duration or require the message to be manually closed? This might be good for things that don’t need to be coded as hard stops but also should persist longer than normal to maximize operator awareness of the message.
Hi @jmlowden - Right now persistence is set account-wide under Account Settings > Player (Toast Message Duration and Toast Error Message Duration, where 0 keeps a toast up until it’s dismissed). A per-action override like you describe doesn’t exist yet. Is the account-level setting not enough because you need different behavior for different messages in the same account?
Correct, I could see some benefit having the ability within a trigger action to specify “0” to require dismissal for more important messages vs. whatever duration is the account-wide setting.
Maybe less benefit to specify an exact duration within the trigger action, since this could get relatively out of scale vs. the account-wide setting if that setting changes and the trigger action is not correspondingly updated.
Thanks @jmlowden, that’s a helpful distinction. A “keep until dismissed” option on the action, with everything else following the account setting, is a much narrower ask than a per-action duration, and it avoids the drift problem you mention. I’ve noted it on the request that way. If others need the same thing, upvotes on this thread help us weigh it!
