Difference Between Running (Tulip Player) and Testing Apps (Developer Mode)
hello all,
in today’s Office Hours session, we covered the difference between Running and Testing apps.
the main difference is that Running apps opens the apps through the Tulip Player installed on your computer, whereas you can use the new Developer Mode runs app in a tab in your browser. running apps in Developer Mode allows you to simulate using different scenarios (for example, running the app at different stations or with different operators). furthermore, Developer Mode will not log any completions or update the records within Tables so there is no need to worry about messing up production data.
here’s the link to the video:
thanks @ishmaelg for the great question!!
