We use Tulip for work instructions in my company so when we have to make a single trigger change we have to replicate it over hundreds of apps, would be very useful to have a system where you can have multiple base slides that all the apps reference so making bulk changes is quicker and easier
Welcome to the Tulip community!
First off, I had someone else teach me this quite recently: In case you didn’t know, you don’t automatically vote for your own suggestions. If you meant to vote for yours, please remember to do so!
With that out of the way, this is a great suggestion! I can’t find a feature request post for this specifically, but it’s been mentioned in other posts. This post specifically has a reply from @Pete_Hartnett: Copying Base Layout from one App to Another that suggests they are aware this would be useful.
I also think this would tie in well with these two suggestions (not my own, but I do have replies / votes) in support of them:
Layers in App Editor
Add a base layout for each step group**
The simplest solution I’ve found for this problem is just to publish an application that is only your base layout and a blank step.
Then simply copy that app and rename it when you create a new app.
Thanks @oscar.deakin. This request has come up before and is tracked alongside an existing request for a shared base app that propagates changes to every app built on it. For reusable trigger logic specifically, Functions can reduce how many apps need edits for a single change. There is no app-level template with live propagation today.
