Platform Release 371 - June 2026
:tada: Exciting news - Release 371 is here!
The Tulip team has rolled out fresh updates across the platform, along with some bug fixes. Check out the release notes and dive into what’s new.
Share your thoughts and questions below :arrow_down:
PLAT-54196 The API reference for the create user endpoint now documents the existing 429 Too Many Requests response and notes that the endpoint is rate limited to 30 requests per minute.
I do see it on
https://INSTANCE-NAME.tulip.co/apiDocs
but Create a user is not updated yet.
It refers to the new doc:
Introduction
May I ask what you mean by “new doc” ?
I am saying that the “create user endpoint” still lack the explanation of “429 Too Many Requests” response and notes about30 requests per minute.
My bad you are right. This is still missing.
I was just curious about your link https://instance-name.tulip.co/apiDocs which is different to my ne :wink:
There used to be an old api doc under this link…
Yes you have to change instance-name.tulip.co part to your instance domain.
My sandbox r373 still has the doc here, and it is updated correctly.
@ta-aoki thank you for flagging this doc, our team will have this page updated shortly!
