Tulip ㅁpplication Ctrl+z Feature Problem
Hello All,
I would like to provide some feedback regarding a usability issue in the Tulip App Editor.
Currently, if you click and drag a widget (such as text, variables, etc.) to a new position, pressing Ctrl+Z will successfully undo the action and return it to its previous position—but only if the widget remains selected. If you click on another widget or deselect the moved widget, the Ctrl+Z shortcut completely fails to work.
In standard applications like Microsoft Excel, the system remembers the history of previous actions, so pressing Ctrl+Z reverts to the prior state regardless of where the cursor or selection is.
If a user accidentally deletes a button or moves an item and doesn’t hit Ctrl+Z immediately before clicking away, it is impossible to recover the changes.
so I would highly appreciate it if this issue could be reviewed and fixed in a future update."
Hey @IsaacIS the lack of proper undo is a real bummer in tulip. Be sure to upvote this product suggestion:
