Converting Integer to Date
Hi Tulip Community,
I feel like I’m missing something simple here, as I’d imagine this is a common need in variable-type conversions:
A connector function I run returns an Object list which I am displaying in an interactive table. One of the variable types of this object list is Text and another is Date/Time. My goal is to find a certain searchstring in the table and return the date.
Using MAP_TO_TEXT_LIST and MAP_TO_NUMBER_LIST, to create arrays, and ARRAY_INDEX_OF to find the index of the searchstring then ARRAY_VALUE_AT_INDEX of the number list (date list) to get the proper date in Unix timestamp (number format).
How do I convert this Unix timestamp to a Tulip Date/Time variable? I can’t find a function in the expression editor to handle this.
Is the issue when setting the connector output to date/time, that there is no map-to-list function for date formats?
I mean that would solve the problem too.
But Tulip is allowing me to store the date column as a number in a number list, which is find by me for this use case. I just need a way to convert that number (which is in Unix format) back to date.
As a workaround, you can make a SQL connector and build this function:
(if your format is in seconds but not milliseconds, just remove the “/ 1000”)
You can then use this connector function as a converter.
I don’t know if there is any easier way to solve this natively in the expression editor.
EDIT:
Here you go:
Make sure, you calculate second or milliseconds, whatever you have available!
Thanks Thorsten, I’ll use this work around of adding to the Unix origin date. Hoping to possibly see an added function in the future for this. Thanks for your help!
@thorsten.langner thanks for the great help here!
@iamwout - I changed this to a product suggestion so we have the request for a native function in expression editor to make this easier logged in our system :slight_smile:
@thorsten.langner @iamwout Actually was just told of another way to do this!
There is a functionality in the expression editor for this, albeit a bit strange texttodatetime(totext(:miliseconds), ‘x') or texttodatetime(totext(:seconds), ‘X')
Moment uses x and X for time since epoch; Moment.js cheatsheet
