Device History Widget Print Enhancements
The Device history Widget includes the function to print, based on the tables/filters selected.
As a system owner, I want the device history widget print function to be configurable, so that I can add content to the print rendition of the history, including but not limited to page numbers, header, footer, and a confidentiality note.
Acceptance Criteria:
The print layout of the Device History Widget shall allow to add texts to header/footer, page number, disclaimer/confidentiality notes for each page to be printed or saved via PDF.
Along the same lines, is there a way that we can configure the device history widget so that our company logo is displayed? Or even a ‘no logo’ option? This would be for Audit purposes. @Beth do you know if this is possible or any potential workarounds?
Hey Alec -
I checked with the team and right now there isn’t a way to display a company logo or remove the logo all together. I did update this request internally with your feedback so the team is aware of the need!
