How can Web Components be used inside Tulip?
I wanted to know how can Web Components be used inside Tulip?
I tried to integrate a Gradio app in tulip but wasn’t able to import the .js file required in the script. Please respond on weather this is possible?
Hi @sarvesh.angadi -
Are you trying to embed the Gradio app within a Tulip app? Are you using a custom widget or another method?
Hi @Beth i was trying to do it using a custom Widget.
Hi @sarvesh.angadi,
It seems your Gradio app is quite complex, I don’t think it can be hosted in a custom widget.
What you can do, is to install your Gradio app in a container (Amazon for example) and call it from Tulip as a website (open a new tab or directly embedded with Custom widgets).
Kind Regards,
Kevin
