How to send notifications using the scheduler
How can I send notifications using the scheduler? For example: Send alert emails to Joe between the hours of 3:30 pm and 11 pm, on Monday through Friday.
hello @Neo, thanks for posting!!
just to confirm, do you mean Schedules and Shifts?? if so, you could set the Schedule at which you’d like to send the emails at:
and you could then add a Trigger similar to this one to check the schedule and send the email if it falls within a specific Shift:
does this could help in what you’re attempting to build?? let me know!!
I realized the cause of my issue from your screenshot, my trigger was correct but would not respond. When I reviewed the Schedule and Shifts menu my ‘Weekday Schedule’ was set to a default value instead of the new schedule I had created, causing my trigger not to respond.
Selecting the correct schedule resolved the problem.
Thank you.
happy to hear @Neo, thanks for the update!! it would be great if you could share what you build in Show and tell - Tulip Community.
