Hi @gio
I cannot replay in the other comment, If I use Array to a string option, then How Can I count in a dashboard what is the most common option choose?
I really appreciate it
Hi @gio
hello @LXM8843,
this can be achieved using multiple Count Where True Operations in the Analysis.
here’s the Table:
as you can see, Option 1 has 2 records, Option 2 has 1 record, and Option 3 has 0 records. is this what you’re trying to build??
thanks for posting!!
hello @LXM8843,
the dropdown that is currently open will only be populated with the Array variables you have in your app. could you send a screenshot of the Variables modal from your app??
thanks!!
hello @LXM8843,
if you select Que Mejorar as the Array, and Static Value > , as the delimiter does the variable not save correctly as a String?? for reference: Multiselect buttons - save into table record - #2 by gio.
no, maybe we can check tomorrow in our office hours
yes, we can review in tomorrow’s Office Hours no problem.
we’ll post an update here once resolved.
in today’s Office Hours the solution was found using the Join to String action.
