Platform Release 386 - September 2026
:tada: Exciting news - Release 386 is here!
The Tulip team has rolled out fresh updates across the platform, along with some bug fixes. Check out the release notes and dive into what’s new.
Share your thoughts and questions below :arrow_down:
In the Button widget’s icon picker, added an exit/sign-out icon, so “Log Out” and “Exit app” buttons can use a matching icon instead of the power symbol.
  • There is still a redo icon but no undo (in what scenario would you use a redo then?).
  • The Arrow Back Chevron and Arrow Forward Chevron do look different (weight and alignment)
I think this could have been fixed in the same go…
