Hi everyone,
Here is my use case.
I’m scanning barcodes with the data “A0000015665279” inside it.
I want to extract from this code only the part “15665279”.
I tried to use the following REGEX to do this : /[A-Z]0*(\d+)/
I tried to use the REGEX_MATCH function in TULIP :
But I don’t have any outputs in my variable.
Any advice on what I’m doing wrong ?
Paul
ta-aoki
2
I do not know if this is expected behavior, but it seems like you should either try these
- ‘[A-Z]0*([1-9]+)’
- ‘[A-Z]0*(\d+)’
It worked in my sandbox(r303.1)
ta-aoki
3
OK, this community post also seem to escape \ .
You should either try
- ‘[A-Z]0*([1-9]+)’
- ‘[A-Z]0*(\\d+)’
Please note that you need two ‘\’ before ‘d’
ta-aoki
4
Maybe you would like to vote for this Product Suggestion!
Hi @ta-aoki, thank you for the inputs ! The REGEX you sent are working perfectly
