Exciting news - Release 299 is here!
Share your thoughts and questions below
I see different ticket number with the same description. Is this correct ?
https://support.tulip.co/docs/factory-298-release-december-2024
PLAT-39813 Fixes an issue with the HTTP online status checks that is done when the connectorRepoForOnlineStatus feature flags are used.
https://support.tulip.co/docs/platform-release-299-december-2024
PLAT-40019 Fixes an issue with the HTTP online status checks that is done when the connectorRepoForOnlineStatus feature flags are used.
Hi @ta-aoki , as I checked this bug was resolved in release 299 and mistakenly included in r298, so I will adjust the release notes accordingly. Thank you for highlighting this!
