Add pop up functioniality
Are we able to add pop up function without creating new step? It seems like a lot of effort to recreate new step with pop up.
I saw below article back in 2021 and talk about work around but seems little cheesy:
Hi @Leooh0411 ,
I know you’re asking for an implemented solution. But as workaround you could realize this feature with a custom widget.
I found one Alert here in the Community and changed it to my needs. Then I also created one with a confirmation possibility so you can accept and deny.
This looks something like this:
Both versions do pop up, if a counter variable inkreases.
It is not a master piece of design and if the TULIP Player is the Browser one, then it pops up at the very top of the page. So I support your suggestion.
But maybe this helps as a temporary solution for you.
Let me know if you are interested in this custom widget.
By the way: Did you know, that you can also vote for your own suggestion? :wink:
