Is there a trick to make the table column widths stick? Looks like they always get reset regardless of whether they are used in an app or anywhere else…
Hi Sebastian,
Thanks for bringing this up! Unfortunately no trick yet …
Fixed (a.k.a. “sticky” - nice term!) table column widths is a known limitation, in the Analytics backlog. I’ve upvoted it for you!
- Olga
is there an update on this issue? I would also like to permanently increase the line limit.
