Apps in read-only, some trigger field is not display fully
Hello
Displaying an apps in read-only (view previous publish version or support team that have viewer role), the function name is not display fully. For people is difficult to understand the logic and function used, .
It could be great to have tooltip to display the full function name.
Awesome suggestion here and can see how this would be a small, but important thing to improve quality of life. The Tulip Team is looking into it :slight_smile:
Hi
Does the product will plan a change and when?
Today I need to give access to “Apps Change” to support and viewer people in order to display the full name of the trigger, that it is a risk for us.
Hi @Nicolas ,
I’m a new Product Manager, onboarding to this space.
This feature request is not currently on the roadmap, but let me check with the team for additional context and circle back if this is easy to fit in.
  • Olga
Same problem with the Static Value text.
I have to open the browser developer console to find out what the text is.)
Please fix.
