Array IndexOf()
Is there already a kind of IndexOf() function to find index for a specific value in a simple or complex array?
Hi @youri.regnaud ,
I hope that helps:
Thanks, Do you know if you can use regex if a value match a regex expression?
HI @youri.regnaud ,
this will deliver all matches as an Array:
Does this help?
Edit:
To check if its a total match you could build something like this (this checks if only capital letters are used):
Maybe thats something for an custom widged, if you need this more often.
My question was more if i can find index in an array that match a regex expression. Thanks for your help
You could send it to a connector function and let the connector solve the issue (here looking for an “e” at the end with at least 4 leading characters):
I guess in most cases the “like” without regex is best (I added some examples as comments in the SQL…)
But maybe a custom widget is the best solution here?
I also try this :
