Sometimes you might want to send email messages to users who aren’t registered in your instance. Actually, there are a lot of things you can do with SNS topics.
Using some simple services from AWS you can build a simple messaging layer.
Let’s create a Unit test App to manage the SNS topics.
To do so, lets create a quick lambda that can create topics.
import json
import boto3
import logging
import os
logger = logging.getLogger()
logger.setLevel(logging.DEBUG)
runtime_region = os.environ['AWS_REGION']
sns = boto3.client('sns')
def lambda_handler(event, context):
print(event)
topic = event["topic"]
try:
topic = sns.create_topic(Name=topic)
logger.info("Created topic %s with ARN %s.", topic, topic['TopicArn'])
except:
logger.exception("Couldn't create topic %s.", topic)
else:
return topic
Attach a policy to allow the lambda to create topics. I wanted to limit the account to altering topics that start with TULIP-
"Version": "2012-10-17",
"Statement": [
"Sid": "VisualEditor0",
"Effect": "Allow",
"Action": [
"sns:DeleteTopic",
"sns:CreateTopic",
"sns:SetTopicAttributes"
"Resource": "arn:aws:sns:*:AWSACCOUNT:TULIP-*"
"Sid": "VisualEditor1",
"Effect": "Allow",
"Action": "sns:ListTopics",
"Resource": "*"
I like to trigger lambda’s from Aurora Postgres, so create an IAM policy to allow it.
Now make a postgres function to call the lambda.
CREATE OR REPLACE FUNCTION globalstructure.create_sns_topic(topic text)
RETURNS text
LANGUAGE plpgsql
AS $function$
declare
create_json TEXT;
response TEXT;
err_context text;
_topicarn text;
begin
RAISE INFO 'Started';
select
into
create_json row_to_json(t)
from
select
topic
) t;
SELECT into response payload FROM aws_lambda.invoke(aws_commons.create_lambda_function_arn('tulip-create-sns-topic', 'us-east-1'),
create_json::json,'RequestResponse'
RAISE INFO 'response:%',response;
select into _topicarn response::json->'TopicArn';
select into _topicarn replace(_topicarn,'"','');
RAISE INFO 'response:% ',_topicarn;
return _topicarn;
EXCEPTION
WHEN others THEN
GET STACKED DIAGNOSTICS err_context = PG_EXCEPTION_CONTEXT;
RAISE INFO 'Error Name:%',SQLERRM;
RAISE INFO 'Error State:%', SQLSTATE;
RAISE INFO 'Error Context:%', err_context;
return null;
END;
$function$
Then finally, call the postgres function from a tulip connector
Wash, rinse and repeat for other functions to
- List SNS topics (useful to show what possible topics are available)
- Subscribe to an SNS Topic (it sends an email that the user clicks to verify the subscription)
- Publish to an SNS Topic
