Bubble callouts
We find ourselves using bubble-style call outs in our work instructions. It would be helpful to have these be preset as an option in the “assets” pulldown. Currently we have to fake these as a two part process (using text and and then copying circles over the text).
hello @neil, thanks for posting!!
have you considered embedding a Text Widget and adding a border radius that is half the width (and equal height) of the Widget?? based on what I’m understanding, this should cover most of the functionality you’re looking for:
let me know if I missed something
Thanks, yes, these are a better solution that what I had. There is still not an easy way to add a stroke or border to the callout, but it works fine with a solid background. We’ll use these.
OK, great to hear @neil!! thanks again for posting.
