CA signed Certificates in Custom Widget
Is there any way we can upload/use CA signed certificates in custom widget? We have an azure app gateway endpoint which we need to call from custom widget, and it requires certificates for authentication.
any File upload option or can we call connectors from custom widgets? the idea is, Connectors have option of TLS setting which can connect with Azure app gateway, we can call the endpoint in connector and provide output of this to custom widget?
Custom Widgets cannot upload or use CA signed certificates, and they also cannot call Connector Functions directly. Widgets run inside a sandboxed iframe and only support HTML, CSS, JavaScript, Props, Events, and optional external libraries. TLS settings and certificate handling need to be done in a Connector instead. The supported pattern is to let the widget fire an Event, and then have an App Trigger call the Connector Function. This community thread explains the limitation around calling connectors from inside a widget:
https://community.tulip.co/t/calling-a-connector-function-from-within-a-custom-widget/8551
