Clear Button on Input Widget does not Activate Widget Triggers
Hi Tulip Team,
When using the clear button in an input widget, it does not activate the widget’s triggers.
My use case for this is that when this input field is cleared, I also want to clear a variable and table placeholder. It seems the clear button does not activate the “when input is exited” or “when enter key is pressed” triggers for the input widget.
I feel it is intuitive expected behavior that the clear button would be able to activate triggers in the widget.
Wout
Thanks Wout, agreed that seems odd.
Let me triage this with the team and circle back.
