I have created an app to create and print badge ID cards on a ZebraZC100 printer. The printer requires an image size of 1006 x 640 Pixles.
Is there any way to set the step resolution to 1006 x 640?
hello @Jeff, great question!!
it is not currently possible to set custom sizes for Steps. however, you can Manage Custom Sizes using the print system dialogue to only print a selected area. on my machine, this is where it is accessed:
for example, setting a custom print size of 2 inches x 2 inches for the following step:
would result in the following document being printed:
Untitled.pdf (18.7 KB)
does that work as a sloution for you??
finally, this is a great suggestion and I would recommend posting in https://community.tulip.co/c/product-suggestions/10!!
