Custom Widget : How to Fetch Tulip Table For Making Charts In JS
How do we fetch the Tulip Table Record to Custom Widgets.
Is it possible to fetch the Tulip table / Table Records to custom widgets for making charts/graphs…?
Check out this widget, you will need to generate an API token, and add that to the js, but otherwise you should be good to go.
Screen_Recording_2023-07-19_at_11_47_42_AM_AdobeExpress (1)
customWidget-Custom Table Viewer - select multiple rows No Keys.json (5.0 KB)
Hi Pete,
Do you have it on the roadmap to include this feature without API tokens? (We have restriction to use them)
BR
Szabolcs
Pete, Thanks a ton for solving the issue.
displayData();
const colsToHide = [];
let selected = [];
async function callAPI() {
  //console.log("in fetch machine data")
  const authorizationBasic =
    "apikey.2_xxxxxxxxxx";
  let myHeaders = new Headers();
  myHeaders.append("Accept", "application/json");
  myHeaders.append("Authorization", "Basic " + authorizationBasic);
  myHeaders.append(
    "Content-Type",
    "application/x-www-form-urlencoded; charset=UTF-8"
  const myInit = {
    method: "GET",
    headers: myHeaders,
    mode: "cors",
    cache: "default"
  let myRequest = new Request(
    `https://{instanceurl}.tulip.co/api/v3/tables/{tableid}/records?limit=100`
  const response = await fetch(myRequest, myInit);
  const data = await response.json();
  return data;
@Pete_Hartnett do I have this right? is the Secret go anywhere in the js or just the key?
Hello Jordan,
Hope you’re doing very well. Thank you for your support and for sharing your code.
I want to say that with the API key we will need the functionality code for the secret key in JavaScript.
In addition. I’ll tell you if it works without a secret key. I will try to implement your ideas in my code if it runs without any bugs or errors, and by running it we are able to bring the table to a custom widget then it will be really economical and if it happens then I will let you know.
Regards,
Dushyant Deshwal
Hey Pete, Thanks for providing us the running product. It would be a great help if you can share the code you wrote in HTML.
 <head>
  <body>
  <div id="body"></div>
  </body>
  <script>
             callAPI();
let selected = [];
//   console.log("in fetch machine data")
  myHeaders.append(
    "Content-Type",
  const myInit = {
    method: "GET",
    headers: myHeaders,
    mode: "cors",
    cache: "default"
    `https://xxxxxx.tulip.co/api/v3/tables/xxxxxxxx/records?limit=10`
  return data;
  console.log("data")
document.getElementById("body").value=data
  </script>
        </head>
This code is not working properly & even I’m not getting data in console. Can you tell me where I’m making mistake or share the correct code?
Did you ever figure out a solution to get this working. I think you need to use the Auth Header instead of the API key from the API token.
However, even using that header I still do not get any return data.
@Pete_Hartnett I’m trying to follow along with using your widget. I added in my Auth Header starting with the “YXBpa…” portion but still having issues receiving/displaying data from the table. Not sure if there is a step that I missed.
Yeah you need to create a BOT & then create an API to retrieve data from tulip table
@Pete_Hartnett We have exactly this need: be able to select multi line in a table.
Today the interactive table widget only permit to select one line. It will be great to enhance the standard interactive table widget with the feature of multiline selection.
Hi @Pete_Hartnett could it be possible to have the same widget taking in input an object list variable ?
Thanks
Hi @Nicolas - there is an open product suggestion asking for just that! If you would like, please vote / comment on that thread here: Multi-Select Interactive Table
@scizeron Pete will get back to you on your question here
Hey @scizeron
Here is an example of this widget that can take in any object input and will render that array. In this case I am relying on an object list prop called “Example Object Input”
displayData();
let selected = [];
  const data = getValue('Example Object Input')
  console.log(data)
  return data;
async function displayData(){
    let data = await callAPI();
    addCols(Object.keys(data[0]));
    addRows(data);
function addCols(keys){
    //console.log(keys);
    const toSkip = ['createdAt','sequenceNumber','updatedAt']
    for(let i = 0;i<keys.length;i++){
        let header = document.createElement('th');
        let cleaned_name = keys[i];
        header.innerHTML = cleaned_name
        //if (toSkip.includes(cleaned_name)){
          //  header.style.display = 'block';
       // if (hiddenCols.includes(keys[i])){
          // console.log(keys[i]);
          // header.style.visibility = 'collapse';
        $('#headers').append(header);
function addRows(data){
    //console.log("in here");
    const keys = Object.keys(data[0]);
    for (let i = 0;i<data.length;i++){
        //each row
        //console.log("Adding row");
        const tr = document.createElement("tr");
        tr.setAttribute('id','Row '+ parseInt(i))
        $(tr).attr('id','Row '+ parseInt(i));
        for (let j = 0;j<keys.length;j++){
            let field = document.createElement('td');
            field.innerHTML = data[i][keys[j]];
            tr.appendChild(field);
        $(tr).on('click',function() {
            if (tr.className == 'highlighted'){
                tr.classList.remove("highlighted");
                removElement(selected,data[i].id);
                fireEvent("Selected ID",selected);
            else{
                tr.classList.add("highlighted");
                selected.push(data[i].id);
        $('#tbl').append(tr);
    //console.log("Rows added");
function removElement(arr,toRemove){
    var index = arr.indexOf(toRemove);
    if (index !== -1) {
      arr.splice(index, 1);
    return arr;
function toTitleCase(str) {
  return str.toLowerCase().split(' ').map(function (word) {
    return (word.charAt(0).toUpperCase() + word.slice(1));
  }).join(' ');
Hi Guys,
don’t know if somebody already mentioned this but you can easily use your json data as source for jquery datatable embedded some chart.js charts.
So for example:
Sources :
