Display fast-updating data in Tulip Player using WebSocket
Hello Eveyone,
I was searching a way to display fast-updating data in Tulip Player. There are some sensors and measurement tools that sends numerous real-time data as serial data. First of all, I tried using Machine API via Node-RED. But it was not good for performance.
Finally, I found that Node-RED can change serial data to WebSocket connection easily. And Tulip Player can access ws://localhost:1880 without any security issue. So, I created a custom widget which can connect ws://localhost:1880/ws/test via WebSocket.
Even if sensors send a lot of data in a short period like 10Hz, Tulip’s custom widget can handle these data with no latency because this is a local connection between sensors and Tulip Player.
Hope this helps for someone.
custome_widget
Akira
This is so cool! Thanks for sharing!
You have nodered running locally on one machine and Tulip player connecting to itself? I did similar for MQTT but went cert route… its a pain! :slight_smile: Working version – MQTT and Tulip Custom Widgets – Michael Ellerbeck
@mellerbeck
Yes. I have Node-RED and Tulip Player running locally on my PC!!
I encountered the same cert issue when I tried to connect to other host like “ws://computername:port”. I realized that we need to use a certificate with a right domain name. So, the easiest way is using ws://localhost:port to avoid this cert security issue. Using a valid authorized certificate by security vendors is another solution but it’s hard to use in a factory which doesn’t have domain name.
You know, it would be interesting if Tulip could generate a letsencrypt cert for its edgeMC devices.
