Display Rounded Variables
Hello,
I’m new to Tulip. I’m having an issue displaying the rounded value of a number on a Variable widget. I already selected the correct data source but when I test it on Developer mode, it’s not displaying anything after pressing the Round button. Can anyone help me?
Hi @OREJ !
Great question. Are you using a trigger on the button with expression editor to round the number? This Tulip University challenge actually walks through how to do rounding step by step and may be helpful to you here! https://university.tulip.co/round-a-number-to-the-nearest-tenth/14050
One quick thing off the top of my head to think about - for the number you are wanting to round, do you have that number input widget set to decimal (under “format” on the widget menu) with the correct amount of decimal places? (see example below)
If that doesn’t help, I’m happy to further problem-solve this with you :slight_smile:
