After this maintenance, the static variables in several drop-down boxes I set all disappeared and an error was reported, as you can see in the image below,Could you help me with this problem
Hey @Jiayu -
Can you shoot a link of your app to support@tulip.co and they can dig into your app specifically? We haven’t see this sort of error anywhere else after the most recent release.
Hi Jiayu,
Does this still happen if you delete the widget and then create a new one again?
Aaron
@aaronstone hello,
When I delete and re-create and configure the widget in the program, it will return to normal, but I need the new widget in the program to still be normal after the next maintenance
Hey @Jiayu -
So this widget was working, and then stopped after the last release? I don’t know of any customers reporting this, and this isn’t something we saw in our QA process, but I would love to see if we can recreate it.
Feel free to re-add it, I think the chances of this happening again is incredibly small.
Hi Jiayu,
If you are experiencing this issue consistently, feel free to file a support ticket by emailing support@tulip.co.
Best,
Aaron Stone
