Enable Expressions as Variable Inputs
Enabling expressions as variable inputs would prevent the need for repetitive triggers scattered all across apps (counters, bools, etc.).
Hi @SportechMCarlsen could you share a bit what you’re running into here? Expressions can be used in Data Manipulation in Triggers, so users can set a variable to an Expression… Screenshots would be very helpful.
