External Library - React Flow
Hello,
In order to enhance the custom widget capabilities, would it be possible to add the free “React Flow” library in the external libraries we can import in the custom widgets?
Kind Regards,
Kevin
Hi Kevin, can you share a little bit more about what you would like to accomplish with React Flow within Tulip? I would love to see how we might solve the problem.
Hello Kevin,
I would love to create Custom Widgets that would display the production steps in a visual manner.
I know that it may not be that useful from a Workstation perspective but it will be invaluable for Supervisors, Managers, QAs that need to have more overview about the process.
Kind Regards,
Kevin
