How can we extract an object within an object?
I am facing this problem while displaying the output received after using ‘Extract value from a document’ trigger in frontline co-pilot.
Hey there!
The reason you’re not seeing many options is because Answer is an object list. You’ll be able to do a lot more by extracting a single object.
Arrays -> Pop from Array -> Answer -> Answer Object
Data Manipulation -> Store -> Variable -> Answers -> Answers variable
This looks a bit confusing on paper, but give it a go in your instance. I’m unsure what your use case is, but this should expose the data you’re looking for.
