Facilitate selection of variables saved for analysis
Greetings.
Very often in my apps, there are many variables saved in the completion table (since they are saved there by default). Sometimes I do some clean-up and remove any variable that isn’t useful. But I don’t have any easy way to do this. I have to manually click on every variable’s “…” button to see if it is saved or not. This is tedious :frowning:
I think we could do several improvements to this. Maybe:
  • add a filter by Saved for analysis or not (see image below)
  • add a Save everything for analysis button
  • add a Remove everything from analysis button
What do you think?
Hi @fti, I definitely can see how this can be tedious and time consuming when you are updating your app variables.
I like your suggestions to fixing this. We will take a look at it and see what we can do.
Thanks for the suggestion!
