It would be really useful to be able to use a Table Query as the source of selections in a drop-down (single select) or multi-select. You’d need to be able to apply a filter (this is why I’m suggesting sourcing it from a query - plus that will also let you decide how to order the items), and select which column.
Thanks! I’ll try that! This would be a good knowledge base article
@wz2b this is a good callout. We’re revisiting all of our Table Queries and Aggregations documentation in the next two months as we roll out some improvements to the features. We’re planning on expanding the use-cases and techniques we cover considerably, and this is a good one to add to the list.
Thanks. FYI I really do search the knowledge base before I ask dumb questions here ![]()
