It would be great to have the ability to define a global expression, which can then be called in any step needed throughout the application. There is a workaround method now where you can have the expressions run every 30 seconds on the master layout and written to a variable and call that variable where you want it. However, you might only want to run these expressions at run-time of the page where the expression is being used.
