Hiring: OT Process Engineer - Merck (Germany)
A really interesting opportunity here with Merck in Schnelldorf, Germany!
"In this role as OT Process Engineer, you will provide technical support to production/shop floor colleagues, troubleshooting, and debugging customer issues. You will also investigate technical incidents and ensure 1st-to-3rd level maintenance support.
Additionally, you will be responsible for ensuring the performance and reliability of a Tulip production system and its interaction with SAP. Your role will involve continuously improving/developing Tulip apps and its backend services for high reliability and fault tolerance. You will also maintain hardware interfaces with systems, such as scales and e-labels, and be responsible for maintaining Tulip documentation and knowledge database.
Furthermore, you will lead digitalization efforts on or close to the shop floor, such as automation, OT, AGVs, and similar production performance improvements."
Check out the full job description below if you are interested:
https://careers.emdgroup.com/us/en/job/277902/OT-Process-Engineer-Schnelldorf-all-genders
