Host Connector OPCH logs - need more detail
On our Onprem OPCH, we closely monitor “connector fail” error per connectorId. We have build several dashbord log and put in place alert per workspace.
Each workspace support team are autonomous to see error and investigate root cause .
Now our difficulty is on investigation, make the link between a log entry (request ID/connector ID) and what have trigger this issue on the shopfloor (which apps, user, station).
For us, it will be very helpfull to add following information on the log:
  • Connector Name
  • function ID and Name
  • User ID and Name
  • Apps ID and Name
Hey @Nicolas -
Thanks for the suggestion - We have a work task in the backlog right now to improve these logs for OPCH, along with making it easier to map these logs to observability tools. This work is in the scoping phase right now, but expect this to get better over the next few months!
Adding one more information very important: “connector environnement”.
On monitoring and alert, I’m only interest on “Production environnement”.
Today I receive too much alert on connector due to apps builder testing function…
One workarround is to setup a hostconnector dedicated to Development (that is for me good practice to segregare prod vs dev infrastructure).
Hi
Any news on this topics.
Since we have put monitoring on OPCH log on Error “Connector Faillure”, we have now visibility on issue. However we see a important limitation to us for investigation. The first question from an Apps builder is always “on which function you have the error” .
As we don’t have on the log the function ID, we need always to ask to Tulip support more information base on request ID, it take time to give this important information for investigation on an issue that impact our business end-user.
For me, the top priority is to get this “function ID” and it is a must have for proper support.
Thanks a lot for your help.
Hello
By going into the detail of OPCH logs, I realize that in case of connector function error, the log Error message don’t contain functionID, compare to log for connection function in success INFO.
See here 2 call, one in success (botton) and one in error:
Could you check why?
This information “FunctionID” is help us a lot, especially to investigate when call is in error.
Moreover, having “userID” and FunctionID” populate to all logs (info, debug, error) will help too.
