Hourly Scorecard Example
Tracking production against targets is a fundamental use case in manufacturing. We have some examples of production trackers and hourly scorecards in our library, but I wanted to try to create an even simpler version using some custom widgets.
Take a look and let me know what you think! If you are interested in this then we can drop it into your instance - fresh out of the oven!
Thanks
Mark
Also, if you can think of a simpler form please let me know what you have in mind!
What happened to this video? :slight_smile:
Hi @sebme. We cleaned our youtube channel a little while ago, and this video may have been a victim. Let me check and see if there’s a way I can get it over to you.
We had taken this down (oops!) but I just put it back up. Thanks for pointing this out
