How do Video Work Instructions fit into ISO 9001 standards?
As i start a project on a video work instruction suite, i wanted to reach out to the community to ask if anyone has experience with what the requirements would be to utilize video work instructions as opposed to written documentation and maintain an ISO certification
Hi Kyle -
You can think of your video work instructions the same way you would text or image work instructions. The data is stored in the same way in Tulip and app approvals prior to use should follow the same process as well! That being said, your video work instructions should be just fine for meeting the ISO regulations.
I am wondering if @MarkStuttard @ASharp-J @emendoza can provide any insights or additional advice here from their own experiences, as they have worked on GxP Tulip use cases and would be familiar with ISO 9001 too!
Thanks for the help!
