How to move a station from "ungrouped" to different group
Hi Team,
trying to move a station from “ungrouped” to different group.
i tried the below step, but when i click the three dot, i get only remove station option even though i logged as admin.
If you would like to move a station once created, selected the Three Dot button at the top right of the station and select Move Group.
please help to support.
Regards,
Kasilingam
Hi @Kasilingam.samy,
Which release are you on? Could you provide some additional information/screenshots?
Sincerely,
Jake
Hi jakerigos,
Thanks
for the response, currently we are using LTS 10.1 release and pls find the attached screenshot.
Regards
kasilingam
This is on LTS 10.6, but the functionality should be the same. If you go to the station group, and hit add a station, you should be able to add the ungrouped stations.
Please let me know if that works.
Sincerely,
Jake
Hi @jakerigos
i cannot find this adding station to the group in LTS 10.1 .
is there any other way pls
Regards,
kasilingam
You should be able to drag and drop stations into the appropriate group.
Jake
Hey @Kasilingam.samy !
Wanted to provide a little screen recording to show the drag and drop behaviour that you’d use on your instance to move stations across any group:
Max
i tried to drag and drop. but it doesn’t allow me to drop.
may be this feature is not enabled in LTS10.1?
is there any other way?
Regards,
Kasilingam
This doesn’t work for me either
Version: r273.1
Regards Chris
Hey everyone!
@ChrisF if I remember correctly, your instance is using the updated UI, which does not have drag and drop functionality, so if you want to move stations between groups you’ll need to use the 3-dot menu next to the station’s name in the panel or use the quick actions on the list of stations in the station group panel.
@Kasilingam.samy thanks for surfacing this, drag and drop is the expected behaviour on your version, we will investigate more.
Hey @Kasilingam.samy,
Do you mind submitting a support request in the platform so that we can better help you solve this issue?
For reference, this is what I mean:
Max
