Implementing "Save Data" Widget for Step-by-Step Progress Tracking
Hi, I’m working on a Save Data Widget feature that will appear on every step in my app. When clicked, the widget should save data to a table. If a user closes the app mid-way, they should be prompted on reopening to either resume where they left off or start over. Any guidance on how to manage the save state and prompt functionality would be greatly appreciated!
Hi @Abhinav -
Thanks for your question and welcome to Tulip Community!
You may find this article helpful, as it walks through how to set up this “pause & resume” functionality into your apps -
https://support.tulip.co/docs/en/pause-and-resume-functionality
If this doesn’t satisfy what you are looking for, it can be helpful to share more about your use case here and we can discuss other options!
