Interaction (Enable state) to all widgets
I see this property Interaction (Enable state) on “Button”, “Single Select”, “Multiple Select”, “Text Input”, and “Number Input” widgets.
However, I do not see it on some other widgets (e.g. “Checkbox”, “Date picker”, “Interactive Table”)
Please add this feature to all type of widgets.
+1 this slight gap does cause some occasional situations where the entire design of an app needs to be changed. All input widgets should have input validity and mark required as similar as possible.
The Interactive Table one is interesting and would be useful, but probably a separate construct.
“Button” widget already has the feature, so I wish the “Interactive Table” should too.
I think all Input widgets and also all widgets which can have trigger assigned should have the feature.
