LTS 12 - April 2024
:rotating_light: LTS 12 is now available to LTS Customers!! :rotating_light:
LTS 12, the latest version of Tulip, introduces improvements to help users make faster decisions on the frontlines, closely monitor their operations, and build apps faster, all while ensuring compliance with new GxP-Ready features.
To get all the details of this jam packed release, check out the release notes in Knowledge Base here: LTS 12 Release - April 2024
Some of my favorite things in LTS 12:
  • Input Widget Validation (so powerful for making forms, and way less triggers!)
  • Universal template in analytics (seamless analysis building!)
  • Stations API (streamlines station deployment, onboarding, and workflow integration!)
  • Custom use roles (get the exact level of access needed for each user type!)
  • Automations beta (build triggers that run in the background using simple, visual logic!)
Can you tell I’m excited?? :nerd_face:
What are you most excited for in LTS 12? Let us know below!
About LTS Releases:
Every 6 months, Tulip releases a new Long-Term Support (LTS) version of the platform for Enterprise organizations in regulated industries to validate before rolling into production. If you would like to upgrade your instance to LTS 12, reach out to your Customer Success Manager.
For Tulip customers who are not subscribed to an LTS cycle, these features have rolled out biweekly, in our usual platform releases.
See the latest release notes →
Hi Beth, do you know if LTS 12 brought along with it Checkbox labels? Checkboxes created prior to LTS 12 now appear to have a label automatically applied to it (L4 Name / Level 2 in the image). But stranger, it is not occurring with all of the checkbox widgets (L3 name in the image).
Any thoughts on this?
FYI @vch
Hey Kevin,
Yes, this was a change in r271 / LTS 12 to encourage best practices of labeling input widgets. My understanding is that all newly created widgets will appear with the automatic label, but existing widgets will remain as is.
Is this the behavior you are seeing? Did you add a new checkbox widget and see the label but the old ones do not have it?
Hi Beth, thanks for the reply. No, some “old” widgets (but not all) are appearing with the automatic label. But, that is good to know that this behavior is a result of the LTS 12 release.
Best,
Kevin
@vch FYI
