Machine Timeline Formatting
I currently utilize the “Machine Timeline” widget in an app that allows operators to select downtime reasons using the Review Downtime button. Assigning downtime codes to specific time intervals is very helpful in this regard.
  1. Is it possible to add in functionality to alter/move the Review Downtime button? Currently, it has a static size and does not scale with the rest of the timeline when it is enlarged, which can make it hard to locate on the screen. (it would also be helpful if we could tie the “enter downtime reason” modal into a normal button trigger)
  2. Is it possible to set dynamic time ranges for the machine timeline? For instance, tie the timeline start time to a variable (i.e. Batch Start Time). Currently the best option is to use a relative time range (i.e. last 4 hours).
thanks!
I really need to be able to make the Time range a variable that can be adjusted in app so that I can look at different “from” to “to” times" this would allow us to compare different shifts against one another.
The flexible configuration of the timeline period is also frequently requested by our TULIP customers.
Any update on this one?
