Meaning of "Shift Name"? and display bug
what’s the meaning of this App Info?
And there is a bug in the selection menu:
vs
here the parent point “Current Date and Time” is missing or has the entry “Shift Name” two child entries?
Regards Chris
Hi @ChrisF ,
Shift name is based on the shifts, which are available in settings.
For Current DateTime, it should be selectable!
Sincerely,
Jake
I think he is just saying that the indentation of the dropdown list is screwed up.
This has been a bug for a long time.
@danielpomeranz thanks for clarifying this.
So I guess I need to make a product suggestion for this bug? :wink:
Regards Chris
Hi Chris! I went ahead and changed this to a Product Suggestion for you, so it is now in our internal tracking system and @jakerigos and team will look into a fix.
Thanks, as always, for the great feedback :slight_smile:
This was released in Release 289 - October 2024 :tada:
