Mobile Player 2.5.1 Release
Version 2.5.1 of Tulip Mobile Player will be available for download in the next few days (as of May 23rd 2025) pending App Store Approval! If you have auto-updates enabled, the Mobile Player application will update in the background, and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the menu.
