Version 2.5.2 of Tulip Mobile Player will be available for download today (August 6th 2025) ! If you have auto-updates enabled, the Mobile Player application will update in the background, and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the menu.
