MQTT Connection with TULIP
Hi Team, I am in urgent need of any tutorial explaining connection with MQTT and create dashboard. Really appreciate
Thanks for sharing those resources, Jason! These are spot on for getting started here.
Not sure what you are looking to accomplish with your use case @vineet143 (sounds like you want to pull machine data for reporting/dashboards), but I also want to highlight a newly released functionality where you can now write to Machine Attributes as well using using OPC UA/MQTT Protocols
