Numeric ID Columns/Composite ID
The ability to change the ID field to something other than text would be very helpful. It would prevent me from having to create additional columns to store data as a numeric type instead of a string. For example, if my part number field is a numeric data type, I want to be able to make it my ID in a table in its proper data type
Composite IDs could also be very useful, similar in a way to composite primary keys in SQL
Thanks for this feedback @sgiarTiff . Better handling ID fields is on our radar, including e.g. autoincrementing IDs. We don’t yet have a specific project prioritized but are actively monitoring upvotes on product suggestions for future quarters.
