Platform Release 370 - May 2026
:tada: Exciting news - Release 370 is here!
The Tulip team has rolled out updates across multiple features, along with some bug fixes. Check out the release notes and dive into what’s new.
Share your thoughts and questions below :arrow_down:
Added a new trigger action: “Input Validation” > “Validate All Input Widgets”. This action validates all input widgets on the step and displays errors for invalid fields, if applicable.
Thank you!
I thought the default behaviour of the input widget validation not happening until the Enter is pressed is sometime confusing to the users because it would not show the error message unless they find out which input widget was violating the validation.
Now we can just put this action to “On step enter”, so the user will know which widget is violating the validation rule from the beginning.
