Exciting news - Release 373 is here!
The Tulip team has rolled out fresh updates across the platform, along with some bug fixes. Check out the release notes and dive into what’s new.
Share your thoughts and questions below ![]()
Great news that file could be now send in connector function input!
I made some test with echo api with a pdf document, I see that “files” body-part are sending with:
“name”: “MyFile”
“fileName”: “MyFile”
“Content-Disposition”:“form-data; name=“MyFile”; filename=“MyFile””
“Content-Type”: string"application/octet-stream"
With this body, the fileName with extension “myfile.pdf” is not pass and Content-Type is not pdf. Most of target system will not able properly digest this body.
I have made same remark on “image” input: https://community.tulip.co/t/connector-image-input-file-need-the-correct-type-and-file-name/16298.
In Postman, testing a POST multi-part with a file input give me a body:
fileName: MyFile.pdf,
Content-Disposition: form-data; name=\Myfile; filename=\MyFile.pdf,|
Content-Type: application/pdf
